1 - 7 of 7 Posts
Dear all, in somedays, i will buy B&W 600 for HT, but between 683 or 684 for best? Who can give me advice 683 or 684? thanks alot
my HT:
Front: 602S3 (replace by 683 or 684 ?)
Center: HTM61
Sub: 610
SR: JBL control5
AVR: Yamaha 1800
My room area: 13m2 (3.2mx4.2m)
If you have listened to these speakers the sound quality choice should be obvious between the two.
When I listened to the B&W speakers each model up sounded better than the one before it to my ear and I did not need to switch back and forth more than once to hear it.
Based off of my observations, if you have the coin get the higher model speaker.
Discussion Starter · #4 ·
thanks all, but Ya 1800'power is enoght to control 683? (684 is good, Ya 1800: 130wx7, connet bi-amp for 683, 683 need power 200w/ch)
Please some advice! thanks
The rated impedance (3 ohms min) and sensitivity (90 dB/W/m) is the same for the two, and the 683 adds an extra bass cone. It is also a true 3-way design. I'd go with the 683.
The power specs you are looking at are max power ratings (150 vs. 200 W). Assuming the receiver can really put out 130 W, I doubt you'd notice the difference on most program material. However, imo, you'll get a lot better sound using an external amp, e.g. an emotiva, Bryston, or whatever. Yamaha has always sounded a little "soft" to me on the low end (low damping factor?) B&W generally does better with high-DF amps, imo, and having a receiver rated for 4 ohms is one indication of that. I don't know if the RVX-1800 is or not (doesn't seem to say in the specs?)
HTH - Don
Discussion Starter · #7 ·
HTH - Don
Originally Posted by RonaldoCombs /forum/post/18313103
Don't stress on those specs - you'll be fine. Did you listen to the CM5s?
Ron
thanks alot. Finnal I choise 683 but Ya 1800 have not enought power for 683. In future i will use ex amp.
My plan: Rotel 970BX monoblock? 870BX monoblock or Ya Z11? i have some advice for this choise? thanks alot.
1 - 7 of 7 Posts
