  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Help choose configuration...
632 Views 0 Replies 1 Participant Last post by  fmjnax
The above image is a general picture of my main components in my HT setup. I currently only have a single cable so when I switch to the XBOX or play a DVD on the receiver, I have to swap cables back and forth. It's time to change that!
My TV has 2 HDMI and 2 Component Inputs available. I need to send video to the TV from the XBOX (for games), the AT&T STB (for TV), and the LG Receiver (for movies... although the XBOX can do it just as well so this isn't entirely critical). All audio will be handled via TOSlink. I currently own 1 HDMI and 1 Component cable. I need to buy either 1 HDMI or 1 Component cable.
What I need to know is what cable should I buy and what system should get what cable. What I'm thinking is I buy another HDMI and run both the XBOX and the AT&T STB via HDMI (this way I can provide the absolute best quality for gaming and TV). I will then use the Component for the AVR and decide which displays DVD's the best between the HDMI XBOX and the Component AVR. How does that sound?
See less See more
2
1 - 1 of 1 Posts
1 - 1 of 1 Posts
