Originally Posted by sick121 /forum/post/0
Wow. first I want to thank people for their informed responses. My zip is 95326 which is in Hughson, CA. A tiny little city on the skirts of big ol Modesto.
Your zip code places you a fair distance from the broadcast towers for the Stockton and Sacramento stations. For your zip code and adding an antenna height of 200' to get a more complete list of digital stations, antennaweb.org shows:
* yellow - uhf KTXL-DT 40.1 FOX SACRAMENTO CA 308° 58.2 55
* yellow - uhf KSPX-DT 29.1 ION SACRAMENTO CA 308° 58.2 48
* yellow - uhf KVIE-DT 6.1 PBS SACRAMENTO CA 308° 58.2 53
* yellow - uhf KUVS-DT 19.1 UNI MODESTO CA 357° 36.8 18
* red - uhf KQCA-DT 58.1 MNT STOCKTON CA 310° 56.8 46
* blue - vhf KAIL-DT 7.1 MNT FRESNO CA 100° 86.6 7
* blue - uhf KTNC-DT 42.1 AZA CONCORD CA 275° 60.1 63
* blue - uhf KFTV-DT 21.1 UNI HANFORD CA 100° 86.6 20
* violet - vhf KFSN-DT 30.1 ABC FRESNO CA 99° 86.4 9
* violet - vhf KNTV-DT 11.1 NBC SAN JOSE CA 260° 86.2 12
I see analog NBC, CBS, CW stations for Sacramento, but the digital station are not showing. You need to check with the Sacramento local thread to find out if these stations are at full power yet on the digital signal. Odds are that most of these stations are at full power, but antennaweb database is not up to date.
You are around 58 miles from the major network stations in Sacramento & Stockton. All of the digital stations are currently on UHF, but KXTV-DT will be switching to VHF 10 and the KVIE-DT PBS 6 station is currently scheduled to switch to VHF 6 in 2009. Are you considering an attic or rooftop mount? In either case, you should be looking at a directional VHF & UHF antenna. The Channel Master 4228 8 Bay would work for now, but not for KVIE-DT PBS if it switches to low VHF 6 in 2009. For full coverage, something like the Winegard HD7082p or similar medium to long range VHF/UHF antenna is what you should be looking at.
