1 - 3 of 3 Posts
· Registered
I need two RF capable on/off switches.
1: a standard size light switch. Its controlling florescent lights so I cannot use a dimmer. Pretty simple. Physical On/Off and RF On/Off
2: I want to be able to turn my subwoofer on and off. Both remotely and physically.
I already have a normal sized switch on the wall that I'm wanting to replace with a single gang panel with two switches. I'm going to run the existing switch through one of the two, and the subwoofer wiring through the other. If I could have one of those be RF capable that would be excellent!
Anyone have any suggestions? I am using a Harmony 890 if that matters...
· Registered
Isn't Z-wave one of the several RF protocols?
Why would you turn a sub on and off with a switch, and not with a remote control at the receiver?
I think Lutron makes a 2 switch setup, that fits in a single gang - not sure if the Lutron IR system is available with that, though. Why RF, and not IR?
I wonder if Lutron's RadioRa could do this, with a 2-button keypad...may need a controller.
Post back with what you end up with, plz.
1 - 3 of 3 Posts
