1 - 4 of 4 Posts
purchased a "used - like new" onkyo tx-sr508 that turned out to have a non-functioning HDMI out.  The HDMI in, at minimum receive sound because I can play it, but nothing makes it out.  Have read the stuff online about the HDMI board failing, and it actually looks like this board was replaced or repaired as it has the 16v capacitors.  Calling the repair service center tomorrow, but given that the nearest it a few states away and I've seen quotes online between $250 and $540 to fix the same issue, I'll likely be returning it.  (already talked with tech support, who believes it is hardware failure after all the tests I ran). To avoid the same mistake, I thought I'd ask for expert input.
What I'm looking for
-at least 4 HDMI 1.4 inputs and one output
-compatible with JBL CS6100 speakers
-not likely to die as quickly as these seem to from the reviews.
-preferably around $250 or less
--- edit to add----
- will be hooked up to lap top/PC, blu-ray, roku, and xbox on regular basis
Discussion Starter · #3 ·
Discussion Starter · #4 ·
~~found a cheap denon 2113ci manufacturer refurb that's only slightly outside the price range I as looking at. Wondering if there have been any issues with those. might be willing to pay up if there are no concerns.
1 - 4 of 4 Posts
