Hello,
For viewing old fashioned non-HD dvd's is it worth getting a 720 projector, or would 480 be enough? This is for occasional use, so I would prefer to go the cheaper route if there not a big difference in image quality.
I go for the 720 I am thinking of going for the HC1500, but if I there is not to much difference with a 480, then I would not mind spending less. But I have not found a good place for reviews on "low" definition projectors.
In any case, would projector would you suggest? The setting is a room which is very dark, so brightness would not be a major problem. The projector would be on a very low coffee table about 4 feet in front of the couch, and the screen could be at most 14 feet from the table.
Thanks in advance.
Thanks in advance.
