Status
Not open for further replies.
1 - 3 of 3 Posts
Anyone,
I just had comcast come out and install thier new3 Scientific atlanta 8000HD
high definition DVR box. I have a PE8700 with a RAM electronics DVI cable. I know the projector and the cable works because I had a Samsung 841 (temporary untill I find something else) hooked up and the picture worked fine. I tried every aspect and resolution on the Cable BOX and the PE8700 would not display a picture.
What DVI?
Comcast has not yet enabled DVI on any SA8000HD (except for beta testers).
Scientific Atlanta has not yet finished the software necessary to support DVI on the SA8000HD, and when they do, Comcast will deploy it to customers via automatic software update (after a period of testing).
Until at least mid-November, you are going to have to use component from the SA8000HD.
Fyi, posts related to the SA8000HD belong in the HDTV Recorders forum.
1 - 3 of 3 Posts
Status
