1 - 1 of 1 Posts
Hey guys.
I'm in need of some recommendations to finish out my system.
So far this is what is in the HT:
Mitsubishi 62526 - 62" rear projection LCD TV
Scientific Atlanta HDTV Cable Box
Onkyo 504b - receiver
Sony NS300 - dvd player (I'm looking at replacing this with a progressive scan hdmi dvd player, but I can't decide if I really want to hook everything up to the tv, and use the digital out to the receiver, or if I want the reciever to do all of my a/v switching. At the moment, I'm thinking the latter, so if I replace the dvd player it won't be for a while)
Magnaxov VCR
Playstation 1
4 advent h200s (will be rears and surrounds, but currently setup in a 2.1 system)
I'm looking to finish out my system with two new fronts and a matching center. I am thinking that I would like to get a sub as well. I was hopint to keep the fronts and center under about 250 combined and the sub under 150. I mostly watch tv/dvds, but I do listen to some music every now and again on my HT system.
My other question has to do with cables. I'm told that you should be spending about 10% of the cost of your HT system on cables. How true is this? I need to purchase optical and component cables for the dvd player and the cable box. The VCR and the Playstation run on RCA. Do I really need to purcahse Monster cables or are just regular no-name cables okay?
Thanks for all of the input.
-C
1 - 1 of 1 Posts
