I am wanting to run just one CAT5E from my existing home's distribution panel 150' through a buried conduit (2' underground) to a new garage/apartment's distribution panel. Was thinking of having a POE switch in the garage Panel that then connects to 3 POE security cameras about 50' away.
Is this a good plan-would you change anything? Do I need any special type of CAT5E cable or will any normal cable work since it will be in a conduit underground 2'? Does it matter what type of conduit is used or anything work? Would it be better to run 3 CAT5E cables from the home directly to the cameras (more work & expense) or am I ok w/ my plan to run 1 into a POE switch in the garage?
Thanks for any suggestions & advice!
