Wow I need help with this, I thought this would be easy but Im not sure what to do...
I currently have a Sound Blaster X-Fi xtreme sound card in my HTPC which only has 4 ports, the "digital" port seems to be a pseudo digital port because it is a mini jack plug and it can only handle 2 speakers if I am reading this diagram that it came with correctly...
So how would I connect my PC to my 5.1 speakers? The diagram shows using 3 wires from 3 separate ports of the cord to the receiver, but I'm not sure what those wires are, stereo wires?
Alterantively... I have a Sound Blaster Audigy 2 laying around which I think has a SPDIF optical out port. Unfortantely i do not have the diagram from that sound card to confirm I canuse it for 5.1 speaker system
Also I cannot determine if my receiver would be able to accept that. I have a Sony sTR-DE595 receiver which has two optical ports in the back, one labelled "Video 2 In" the other "CD/SACD In". Something tells me thats not what I can use ?
It also has some orange/beige colored port labelled DVD In/Coaxial under a section labelled Digital. The port looks like an RCA port.
Other then that it has a big mess of red/white rca inputs.
I would like to use the most simple and best quality solution from sound card to this receiver but I'm so lost here, please someone give me some advice
