Thanks for the response Tim. You guys here are the best.
The only led I have lit is "ready". The only other reponse I get is about a half second after I plug the 110v cable in, I hear a slight click from the area of the 110v power supply as though a relay is engaging. I had previously removed the wired remote and added batteries and I/R led to make it into a wireless remote. The LED still pulses. It was working fine, and I verified that I still have I/R output by viewing the I/R emitter pulses with my digital camera. Does the wired remote need to remain in order for the PJ to function? I'm assuming not because it worked without it before.
Tonight, I removed the back panel and reseated all the boards and tried hitting the red reset button to no avail. I saw no signs of anything burned back there and smelled nothing out of the ordinary. I am now reciting the prayer of all amateur troubleshooters "maybe it's a fuse?" But...ummm where to find the fuse? Actually I am fairly adept at using test equipment and have a multimeter handy. If you can steer me in the right direction, I'd really appreciate it.
Joe
