Hello,
First I want to say I'm new to this forum and I don't know exactly where to pose this question. Secondly, I don't know why exactly, although this is just an internet forum, I feel intimidated when posting this. Maybe because I'm asking about low-end HTiB stuff in an audiophile forum? Heh. I usually go to RedFlagDeals to pose these questions but I feel that they have either grown tired of answering Audio questions and that it'd probably be better to go to a audio dedicated forum.
Let's get things started then shall we? I'm a newb in this scene, but I'm interested in learning otherwise I wouldn't even be posting here.
I just bought an HDTV (NS-42L780A12 if anyone is interested or if its relevant) and I'm looking to match it up with a cheap HTiB set that I will NOT be upgrading. I will be selling it off to a friend close to boxing day OR putting into the guest/tennants bedroom, and then buying my first real home theater set piece by piece during the holiday season. I want to mention some things:
1) This will be for a bedroom, I suppose Small/medium size? Like an apartment suite, I don't have the exact numbers for it. Best guess is something like 12 or 11'x9 or 8'?
2) It has to have tower speakers cause' my friend that may take it off me later on says he wants a set with them. I mean, I do admit, tower speakers are aesthetically pleasing.
3) Small budget, since it's temp. When I mean small, I mean 300ish all in type of small.
4) Need a set by late August/early September.
So here are my choices, the source is great for cheap stuff.
Samsung's HT-D5330
- www.futureshop.ca/en-CA/product/samsung-samsung-1000-watt-5-1-channel-3d-blu-ray-home-theatre-system-ht-d5330-ht-d5330/10166806.aspx?path=d02b4c63e64d6ad5d375a21233bb87a den02
and LG's HB906PA
- www.futureshop.ca/en-CA/product/lg-electronics-lg-1100-watt-5-1-channel-blu-ray-home-theatre-system-hb906pa-hb906pa/10167587.aspx?path=71999fd60491d399a5fd54bb7edc831 den02
I think what it comes down to is outputs/inputs? Both are really lacking TBH, but what can I expect. I watch 720/1080p rips of shows/movies and play on my PS3. I'll sometimes use my computer as a HTPC. I will also be using a tablet to connect to my TV via hdmi. Essentially at once I'll be using two different HDMI enabled electronics and my PC (via DVI) to my TV. Everything is generally for HD content.
I've read that the TZ510 has no optical input or something? It seems really important but I'm not exactly sure why. I've read/heard that you need it for true 5.1 sound? The TZ322 is clearance and I will not be able to return it, which is why I want to make an informed decision before I purchase. Both are passive subs...? How do you tell the difference?
Lastly, should I pull the trigger at all on these two sets? Or should I wait for better deals later in August or early September? My budget will stay the same, all in 300ish (little more for the environmental fee/shipping/tax).
Thanks for any input and help,
Transcend
P.S. if I'm in the wrong sub-forum could someone tell me for future reference? Thanks.
Samsung's HT-D5330
and LG's HB906PA
Transcend
