1 - 2 of 2 Posts
Howdy All!
I have an Epson EMP-830 projector that I made the mistake of purchasing off of ebay. While it hooks up smoothly and is a lot of fun, there is a blue streak at the top of the screen, running vertically downward about halfway (pic in attachment). There are also other areas that are much bluer than they should be. I can't seem to get them to go away, although they are not as apparent when I have no input. The blue shows up only on darker colors.
An additional problem is that there seems to be some image persistence in the blue spectrum. If I pull up a menu, then exit, I can still see the blue after image. This fades, but it is annoying.
Is anything here fixable? Or did I get jipped?
Send it back right away. You bought a used projector. If it was not advertised with issues file a complate with Ebay or Paypal or both... not sure on the process here. Otherwise most likely it is old and starting to die.
1 - 2 of 2 Posts
