Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
I have a panasonic PT-47WX53 which is an HD ready tv and I just recently got HD service through Comcast.
They gave me the Scientific Atlanta 3250 HD cable box and have no problem with the service or signal as of yet.
My question is where to find the remote codes to get my Panasonic tv remote to work with the SA 3250 HD box. I was able to get the SA remote to work with the tv but it is a limited remote.
Has anyone else had this problem or know of a solution or could direct me to a solution aside from a universal remote.
· Registered
It's not in the manual that came with the box? Or did Comcast not give you one? You could try RemoteCentral.com if nothing turns up here.
1 - 3 of 3 Posts
Status
