I am looking for some help here, I need some help fixing or finding a replacement for my sync module in my BD 701.
when viewing DVD's on component, after a while, the image will start to creep down the screen... some times going so low as to start re-appearing on the top. at first, this was only happening with movies that had Macrovision, so I finally got a Extron box to start hooking up a HTPC, and I am distressed to find that the same problem exists on RGB as component inputs. and I also noticed a macrovision like change in brightness as the image moves up or down a scan-line or two. I am hoping that this is related, and will be fixed when the sync issue is fixed.
I seem to remember someone saying that this was a fault in the sync module, having to do with faulty capacitors, but after a morning of searching, I am unable to find any posts on the subject.
if someone could tell me what caps to replace, or quote me a price on a replacement or refurbishment of my board, I would be very grateful!
Josh
Josh
