I’m about to install a 120 inch UST lenticular ALR screen but I want to “future proof” the installation as much as possible. What won’t change any time time soon...the screen will be the same (120 inch UST ALR screen) and use of an UST projector. What may change over time is the actual projector model and cabinet/console table below. Changing out either of these (projector or console) will impact he screen height in order to achieve the perfect screen so I’d like to implement some sort of flexible mounting solution for the screen so that I can easily, and fluidly, vary the height of the screen on the wall over time.
Are there already some sort of horizontal mounted (across studs) solutions, hex bolt tweakable (like on some tv mounts for fine leveling adjustments), pulley systems, DIY solutions, or anything else that would let me take the entire fixed screen and move it up or down by 1-2 feet as needed over time.
I understand the protectors themselves have adjustments but I’d like the flexibility to be able to vary the fixed screen height on wall as well.
Thank you for any guidance or pointing me in the right direction!
