https://ibb.co/Xkb46HV
Sorry for the crudeness! I can finally put a projector in my apartment. Dream come true. I’ll try and be concise.
Windows as you can see will let in a lot of light. Daytime viewing won’t be much and I don’t mind if CNN is washed out in the background while I’m eating lunch. That said, a brighter projector will help. I’m going to install blackout curtains so I will be able to get it dark as can be eventually.
Second, you’ll notice the walls are white. I have permission to paint them and was thinking gray regardless of projector but is there a good color in that regard that isn’t going to make my apt look bad if for instance the optimal color were orange? (If that makes sense.)
Finally and most importantly, what size picture can I get with those dimensions? 124.5” inches wide, 80.5” high and 160” distance from wall to wall (not counting projector length)? I suck at these calculators so I’d appreciate help on that.
Budget is $2k~ish including screen if I can, can go up to 2500 if considerable advantage.
Thanks so much guys. The day is finally here that I can have a decent home theater!
Benq tk800. Take what you can get on the screen size.
