Status
Not open for further replies.
1 - 2 of 2 Posts
I've lost the remote for my old Sony SAT-A4
I'm using the receiver in my office now and would like not to have to scroll through the 900 channels. I keep buying universal remotes (one was made by rca, another by sony) but the code just won't work for the receiver.
I've tried the automated search and the manual search. Nothing works. Am I out of luck?
Any one know of a code I could use or a universal remote (cheap) that will work?
Your receiver is probably set to RF only, that's why none of universal remotes are working. You can use the front controls on the receiver to get into the menu and change to IR. Then almost all universal remotes will control it.
1 - 2 of 2 Posts
Status
