Status
Not open for further replies.
1 - 10 of 10 Posts
Do you have a signal to it ? Did you hear the HV crackle and come up ? Do the internal test patterns display ? Do you know the settings of your G2 and Drive values ? Are the tubes turned off (Push Color,8 I think to turn them all on).
Renato
Paul is correct. Color, 8 to turn on all colors. Something else to check would be brightness and contrast. Someone may have helped you by turning them down.
Walt
Discussion Starter · #4 ·
I turned down the contrast to centre the raster on the tubes face. After some seconds all tubes are turned off. I don't hear the HV crackle. The projector seems in standby.
Renato
Sir
Is the unit on a ceiling? If so, power off and try reseating the horizontal sweep board, it is mounted in a metal sleeve between the green and blue tubes. Try also building a shim with some layers of electrical tape in the metal cap for that sleeve, to hold the board up into it's connector firmly.
Guys!
Most likely a failed high voltage power supply or horizontal deflection board, best way to find out is to swap in new modules.
Try hitting the # key to call up the test patterns, then crank up the brightness and contrast. Look into the lenses to see if you can see anything.
Sometimes,
Big(80pin?)connector under Blue tube needs clean/reseating.
1 - 10 of 10 Posts
Status
