Just got my plus he-3200 on the weekend and I have a couple of questions.
First of all I love the unit (especially the price)
My questions are:
1. My dvd is not progressive scan but I remember reading that this projector converts interlaced to progressive internally (bypassing the dvd's progressive scanner) so I would be foolish to buy a progressive scan dvd player because the projector is already doing this.
Is this correct?
EDIT - Found out I don't need a progressive dvd player because he-3200 does change the image to progressive on its own!!!!! A progressive scan dvd player would be redundant (saved some $$$$)
2. When inputting from a computer would the average Joe (me) notice the difference between RGB and Dvi?
3. I've got my dvd player running directly to the component in on the projector now. I want to get a new receiver (about $1000) and run the component cable from the dvd player to the receiver and then out (component) to the projector. Will I experince loss of video going through the $1000 receiver or do I need to spend a ton more to get the same video quality of outputting the dvd directly to the projector.
4. I don't want to buy a screen until I try projecting it on a white painted wall.
What sort of paint is best. Flat white????? - latex or alkyd. Any recommended brand names.
Any advice is greatly appreciated.
My questions are:
Is this correct?
