Hi!
I'm having a little trouble with my 45TX and an Adcom 545 amp I purchased.
I use the Adcom to drive my Paradigm Studio 40s and I preout the FL and FR to the Adcom.
I'm getting a slight pop when I switch sources say from DVD to TV/Sat. ( It does it on any source). It is annoying.
Has anyone else experienced that problem?
Do I need to do anything to tell the 45 that I'm pre-outing? I can't find anywhere in the manual or screens that I need to do so but I thought I'd ask.
I think it may be a slight ground loop but I've did all the normal tests and can't isolate an input that may be causing the problem.
All of my components are two plug except the Monster Power 2000 power strip which has three plugged into the wall.
I'm thinking of buying a couple of 6db attenuator for the Adocm to see if that helps as suugested by another on this forum.
Anyway, just wanted to check and see if anyone has suggestions or has experienced the same problem pre-outting the 45.
Mike
Mike
