Hi. I have a LeadTek Geforce3 I bought off of eBay. The fan wasn't working well so I took a CPU fan I had and put it right on the heatsink. I would think this would give more air than the regular small fan. Still, I am having big stability problems. Specifically, the whole system is crashing. It might not be the card, but I suspect it is since the whole screen turns to grey-and-white shapes that look like the "S"-shape from Tetris. See the picture below, but imagine a bunch of interlocking tetris s-shapes, each about .5" x 1".
I know that my motherboard temperature is low (34c) but I guess the card could be overheating. Still, I think the fan is quite big. Is it possible that it was damaged permanently from prior overheating or overclocking? Has anyone seen this behavior before. It takes down the whole system. Note: I have tried TvTool 9.5.5.5 and 6.8, as well at 55.03 and 44.03 versions of the drivers... all of them crash. However, it can take anywhere from 15 minutes to 2 days for a crash to occur.
What should I do? Thanks. -Tom
