My setup PS3 > Onkyo AVR > HD65 via HDMI. Keystone is +/-3 not sure.
PJ bought in Apr '08 with about approx 50hrs on original lamp
, not sure. (PJ is in a 2nd home, hence the low usage)
I started having shadow running the entire lenght of the right side while watching SD-DVDs via PS3 using hdmi about 3-4wks ago, was ok prior to that. It does not happen while watching BD-DVDs thru same setup.
I watch BDs 98% of the time, so not too bothered, will quickly be a big problem should it progress to all formats.
PJ is setup hanging (very well secured) from ceiling in basement directly below family room. We have an 11month old, who just discovered she can walk and trying to run a.s.a.p., and she falls on her butt quite a bit. Guess diaper not absorbing enough
cos I see the shake on the screen the few times I've been down in the basement using PJ when that happens. Note that the PJ bracked is secured very tightly to the ceiling.
Could the shaking from above be (or have) messing with the PJ Optics?
Haven't used this PJ in over a wk, I'll connect the PS3 directly to PJ (and also the TV) bypassing the AVR, to see what happens.
Sorry for the long story, but thought I'll give you the full scenerio.
Would be interesting to see how the other guys problem gets fixed.
Thx and looking forward to your answers and response.
