Status
Not open for further replies.
1 - 2 of 2 Posts
My initial setup was a RTV 5040 with IR blaster controlling a Motorola cable box (Comcast Seattle area, not sure of model #). Anyway, the box has a serial connection on it and I would now like to control it by serial since it's supposed to be faster, but I can't find where in the menu to change to serial.
Do I have to wipe out my inputs and start from scratch? Will I lose all shows.
IIRC, ReplayTV will not control any cable boxes via the serial port, only some satellite receivers. There should be an option when you choose what is connected to an input if serial control is available.
1 - 2 of 2 Posts
Status
