1 - 3 of 3 Posts
Hey,
I've been looking at a new tv to buy for quite some time now. I have a room where light can be controlled, and will be viewing the tv anywhere from 5 to 12 feet.
It will primarily be used 40% movies (bluray), 40% games (ps3 / xbox360) and 20% tv (SD and HD).
I think 46" is the size I prefer the most. Anything bigger I think is too big for what I'm looking for right now, and I don't care to go much smaller.
I'm looking to spend around $1200-1500 max. I know that's not a crazy high budget that some are you are use to, but it seems that I can get a fairly highly rated tv that meet my needs hopefully.
The model's I have been looking are
Panny TH-46pz85u
Sammy LN46A650
Sammy LN 46A550
Any advice would be great. I've been looking at these models for months and just can't figure out what would work best.
Discussion Starter · #2 ·
any help would definitely be appreciate, specifically if you own one of these tv's and use them for what I am planning to. Thanks
1 - 3 of 3 Posts
