Status
Not open for further replies.
1 - 5 of 5 Posts
Hi!
I recently bought some new speakers to expand my system into a 6.1 one. I was all excited until I put in my disc with 6.1 DTS ES surround sound and pressed play. No sound! No sound at all from any of the speakers!
I've tested the channels with my amplifier and they work. I get sound when I use Dolby 5.1. But it just won't work with DTS ES 6.1.
I've got this amplifier (Yamaha RX-V440RDS) and this DVD player (it says "DTS/Dolby Digital: Yes/Yes (inbuilt 5.1 decoder + digital out)" on the DVD player). It should work, right?
Does anyone have a clue on why I can't get any sound?
Thanks in advance!
Make sure that the DVD player has DTS bitstream enabled.
When you start the DVD, select DTS in the audio menu.
I agree with Ratman, make sure your DVD player is outputing bitstream and not PCM. Also when posting to an English language board, it is normally helpfull if you links ARE NOT IN GERMAN
Is the receiver able to decode DTS-ES? (Probably, if you were able to hook up the 6th channel in the first place.)
You've connected your DVD player to your receiver using optical or coaxial digital, right?
Can you play 5.1 DTS DVDs?
1 - 5 of 5 Posts
Status
