Status
Not open for further replies.
1 - 1 of 1 Posts
Ok, here is my problem,
I received my new 65H80 yesturday and I set it all up with my surround sound system and everything. I turned the contrast down as soon as I turned it on because it comes out of the box set at 100%. I made all the connections and veryfied that they worked, everything was working good. I converge the TV the best I could with my eyes as my friend has my EV DVD. I am using Monster cables and this problem happens in every output. The picture is skewed on the left and the right side of the TV. I was watching ESPN 2 and I noticed this when I was watching the score tracker at the bottom of the scree, it was not straight and it was bending down on the left and the right side. The left side has more of a bend that the right. I did not find any setting to correct this with. And like I said it happens with with all outputs, even DVD movies.
Has any body come accross this? and if you did and fixed it can you let me know how? Thanks in advance.
Juan Ruiz
1 - 1 of 1 Posts
Status
