Status
Not open for further replies.
1 - 5 of 5 Posts
I want to buy a monitor that is compatible with it. I need the scan rates etc. I have tried one monitor and it would not work. Thanks,
Patrick Rogers
Discussion Starter · #2 ·
Thank you!
Should LCD monitors possibly work as well. I am assuming 33khz is horizontal frequency.
Patrick Rogers
Consistent with John's response, here's an excerpt from RCA's official Help page:
Vertical Scan Frequency: 59.94 Hz or 60.00 Hz (program frame rate dependent)
Horizontal Scan Frequency: 33.540 to 33.806 kHz (program frame rate dependent)
High Definition Digital Receiver - DTC100 Help
Larry
It should work with most multi-sync computer monitors. The HD output on the DTC-100 needs to be selected which disables the regular NTSC output. The scan rate is near 1080i or 540p which gives a line frequency of about 33 kHz. The output is like pc video with RGB and two sync lines. The sync polarity is positive, which some projectors and old non-multi monitors can not use. John
FYI,
I have used my DTC100 on the following with success.
CTX VL950 19" pc monitor
e machines 14" eview 14
Samsung LCD Syncmaster 570V 15" flat panel pc monitor
Samsung LCD Syncmaster 17" flat panel monitor (cant remeber the model but its sold at Best Buy).
Mike
1 - 5 of 5 Posts
Status
