Status
Not open for further replies.
1 - 5 of 5 Posts
Hey guys, I did a few searches and couldn't find my answer.
I just bought a silver sensor, the thing rules hardcore. I know get UPN and WB, 38 and 56, in. I locked in at 100% on 4,5 and 7.
My only issue is with FOX, I live literally 8 blocks from the station, don't know if the DTV tower is there or not. I previously had an RCA powered indoor antenna and that picked it up decently, depending on how it was pointed. The silver sensor doesn't get any signal. So my question to you is, why not.
My hunch is FOX DT is actually VHF, not UHF. I don't know how I can check this other than physically buying a splitter and an vhf antenna, which would suck since the silver sensor is so nice and compact.
Can someone please help?
Fox-DT is channel 31, which is UHF.
I'm not sure why you're not getting a signal from them, especially if you're getting all the other stations.
Have you played around with antenna placement?
1 - 5 of 5 Posts
Status
