I have a Panasonic 37" (commercial) plasma mounted in an armoire in my bedroom. I use a Niles IR repeater system. There is a IR receiver (the ceiling mount kind with three pickups) laying on top of the armoire about 10" back from the face. When the plasma is on, I get freaky behavior from my digital cable box and IR-to-X10 receiver that are in my wiring closet; the cable box won't respond to remote commands anymore and the X10 thing sends out random X10 commands. I'm using Niles IR blasters in the wiring closet.
First, is there anything that I can do to alleviate this problem?
Second, I am planning on getting a plasma for my main living area. The IR receiver is mounted inside my center channel speaker which will be directly under the plasma. If I get the consumer version of the 50" instead of the commercial, would I not have the IR interference problems that I am having with my commercial 37"?
