Status
Not open for further replies.
1 - 9 of 9 Posts
I also asked this in the HDTV Recording forum. No replies:( I am looking for
an inexpensive convertor that will accept comonent and output RGBHV (via
5 cable coax) to my Runco. Anybody????
D
Darrin,
Jeff is right. I did an install awhile back where we hooked the component out of an HDTV tuner through a Key Digital KD-CTCA2 transcoder to drive a Zenith Pro895 projector with RGBHV.
The little box worked flawlessly!!
Cheers, Drew
Discussion Starter · #4 ·
Thanks guys. The only thing I think will work is the Key Digital. The AA will
only pass through 480p.
Premium Member
Just to put it all in perspective, the "best" solution is the Extron transcoder...but it runs $800 and up. Key Digital's unit received favorable reviews from Li On, but others have noted that it sometimes has synching issues with certain signals. I would have to think that the Key Digital unit is probably the best bang for the buck; just be sure you can return it if it won't synch on the signal for some reason.
Discussion Starter · #6 ·
I already decided to go with the Extron CVC-200. Just trying to get it
for a decent price. If I could find one for $400.00 I would be VERY happy!!
D
Can it do 15-50 khz and hand XGA 720P resolutions. I am confused on which one I should get. Between the Pro-895 and Pro900. I kind of like the black case.
Discussion Starter · #8 ·
Huh??? Who was talking about a Zenith?
Banned
Darrin,
FWIW, I am using the KD transcoder with a JVC D-Theater machine into a TAW-HD800 CRT projector with absolutely no problems or syncing issues. I would say try it with the guarantee that you can return it if it doesn't work for some reason, as mentioned earlier.
The images I am getting through it from JVC with the new D-Theater titles are simply AMAZING:D!!!
1 - 9 of 9 Posts
Status
