Status
Not open for further replies.
1 - 5 of 5 Posts
Got the Kameleon and like the way it can handle all my devices. BUT I can't use either code supplied for TiVo to get it to run my AT&T Series 2 standalone TiVo. The 800 number is closed except normal business hours so I'll call Mon. to see if there are any other codes.
Until then I used the VCR mode button and programmed in all the functions I want. It works the TiVo just fine except I can not get one button - the "0"(zero) to work. That button works on my Cable box(when I switch the mode to Sat/cable) so apparently it isn't a defect in the Kameleon.
Maybe I've programmed too much in but I haven't gotten the "Memory full" that some report.Any suggestions? Don
I'd recommend investigating JP1, which will make your Kameleon positively sing in addition to making short work of your current problem. See http://www.hifi-remote.com .
Discussion Starter · #5 ·
I was goint to go that route. Bought a new 1994 six months ago, bought the cable to connect to computer; read everything about it; downloaded all the files and was, simply, overwhelmed. I am not a Linux programmer and it all seemed too complicated. Now I have to sell the 1994 that has never been used. Anyone interested? Don S.
p.s. I now have the Kameleon working perfectly.:D
1 - 5 of 5 Posts
Status
