  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Help!!! Location. Location. Location. For speakers and pre/amp!!
337 Views 2 Replies 1 Participant Last post by  Alberts
I heard from a friend that an AMP needs to be close to the front speakers to get optimal sound. However, I see that a lot of home theaters tend to locate their A/V equipment at the back of the room.
Where should I place my A/V equipment in relation to my front speakers?
If the A/V gear is placed in the rear , will the types of speaker connector make a difference in the sound quality?
My equipment:
Proceed AVP , AMP5
Aerial Accoustics 7B, CC3
Sony 7000
CI scaler(on order)
G10 D-ILA projector(on order)
Room Dimension
12 x 24
Frnt Speakers located on 12 ft wall.
[This message has been edited by Alberts (edited August 07, 2000).]
See less See more
Status
Not open for further replies.
1 - 3 of 3 Posts
Hi Allen,
Currently, I dod not use balanced interconnects. The AVP and AMP5 are capable of supporting balanced interconnects. I have Nordost SPM (1 meter) running between the AVP & AMP5. I use DH-LAB silver sonics speaker cables(12 ft) for the front speakers along the 12 foot front wall. I have not purchased rear Speaker/cables at this time. Obviously, If I were to run a long strain of interconnect it would be very prohibitive(SPMs). I would certianly have to switch to a more cost effective brand for interconnects.
Thanks for your input...Albert
"This way, you could also buy shorter speaker cables, and probably do well selling your longer pair. You could then go with either the Red Dawn speaker cable in a shorter lenght, or any cable that you prefer."
Allen,
Thanks for your response. I guess, one could locate all of the major components at the front of viewing(projection screen) area for the best results. Right? Or at the minimum, locate the Amp up front and the rest of the AV equipement toward the rear.
Albert
See less See more
1 - 3 of 3 Posts
Status
