1 - 6 of 6 Posts
Hi im looking to buy an ~~OPTOMAHD131XE I have a120" screen on one wall and im looking to place the projector 4,5metres away from the screen at 6.5 ` height would this be ok to project to the screen and fill the screen please
When ceiling mounting, the HD131xe must have the center of the lens 9" above the top edge of the screen. Real basic math to figure this out. If you want the top of the screen 15" from the ceiling, then the center of the lens must be 6" from the ceiling. I have no idea what your ceiling height is or what your room limitations are, so perhaps this isn't the right projector for you at all. It's cheap, but if you have setup 'demands', then you may have to look for a different model.
1 - 6 of 6 Posts
