1 - 3 of 3 Posts
My Epson TW3800 has a magenta/green color shift from top right corner to bottom left corner.
I changes the HDMI cable from the bluray, and tried a WDTV and computer with same results.
When displaying white text on a black background, vertical edges has a green shadow on the left side and magenta on the right. about one pixel wide. Horizontal edges are a clean cut from black to white.
Should I replace the bulb or send it in for service? Or is this just the quality of this price level of LCD projector?
Thank you, Ulrik
1 - 3 of 3 Posts
