1 - 7 of 7 Posts
I just picked up an Acer H5360 for 3d movies. I know I need a htpc to make it work with 3DBR movies. The only thing I will do with the htpc is watch 3d movies so I need a bare bones system. I have no idea where to start with hardware. I can put it together and I know I need a BR drive, Ndivia 430 card and powerdvd10. After that I need your help. I should also note my receiver doesn't have a hdmi input so I need optical from the htpc. Any help is appreciated.
Discussion Starter · #2 ·
I could really use some help with finding a motherboard and cpu. I'm sure somone is seeing some great deals out there.
Have you looked through the Hardware guides at the top of the forum?
Its an excellent place to start.
Discussion Starter · #5 ·
Forgive my ignorance. I don't see a hardware guide. Can you give me a link? Thanks
1 - 7 of 7 Posts
