21 - 24 of 24 Posts
Also, those are no longer $159 this week....they are back up to $179.
Yep. When a deal is posted you don't take two days to think about it. Grab it and think about it later (within the return period).
Ahh, externals... Don't they void the warranty if you take them out?
Yes they do. If you enter the serial number at their warranty status page you'll see it's listed as an external drive. We were lucky enough to have them make an exception (after we talked with a rep) but your best bet is to keep all of the external components and not break any of the clips... the secret if there is one is to pull sideways not outward.
21 - 24 of 24 Posts
