1 - 1 of 1 Posts
Hey Fellas,
Is this the correct place to ask about LED TVs? If not, could a mod please move it to the correct forum. Thanks.
Budget- I would prefer to stay around $1,000 but I would go up to $1,500 or $2,000 if need be.
Seating Distance- I will most likely be sitting around 8-12 feet from the screen.
Size Limitation: I do not have any size limitations. I would like to get a 60 inch or preferably a 65 inch tv.
Uses and Sources: I mainly plan to console game on this TV with some Netflix and movies thrown in occasionally.
Room Lighting: The room generally varies between light and dark so I would say about average depending on if dimmed or not.
Other Factors: I do not care if the TV is smart or not. I also do not care if it supports 3D. I mainly want something that has great picture quality and works well for console gaming.
I have been looking at the Vizio E650i-A2 because I can get it at Walmart for exactly $1,000.
However, I am not sure if this is the best tv for my needs. Could someone more knowledgable please chime in and give their opinion.
Any suggestions are much appreciated.
1 - 1 of 1 Posts
