I would go with the DV64s also. They seem to be an excellent match with the Center channel unit you have, and they are the proper height for seated listening in your room.
In addition, if you have a really decent AV receiver, you will have a dynamite audio system for music that will blow you away.
I have B&W DM603S2 for my fronts. The secret for great home audio, I believe, is choosing a speaker with at least 2 woofer/midwoofer drivers in the 6" to 8" diameter range. This size speaker in a room up to 20 X 30 or smaller, imparts a very good audio image, assuming they also have a good matching tweeter to balance things out.
You won't be sorry with the DV64's I believe.
