Status
Not open for further replies.
1 - 3 of 3 Posts
Thanks to everyone who has helped me get this working. This is what I have to do so far to stream back to dvr
1. Download to dvarchive
2. Rename file to something simple (ie Simpsons)
3. Dump
4. Edit
5. Convert (I save the files for steps 3-5 on desktop)
6. Export new file back into dvarchive (I have to re-enter the info that should have been in the evt file. Anyway to avoid this).
Basically, I want to know if there is a way to edit and replace existing all at once. I know that you can have the file names as ID numbers but those are hard to keep track of.
thanks
Try reVue.
It takes the commercials as tagged by RTV. You can just open the file and then tell it to 'make new video'. Bingo, new file, all the RTV marked commercials *buhbuy*.
John
1 - 3 of 3 Posts
Status
