1 - 6 of 6 Posts
This is my first post so bear with me. If this needs to be moved to a different forum please do so...
I need some assistance finishing off my home theater. I recently purchased a Samsung LN55A950. It's not delivered yet, but I am stoked to say the least! Now, I need a sweet sounding, yet economically priced sound system. My budget is around $500. I found the Samsung HT-Z520 and its seems to be pretty decent for the money. The wireless rear speakers (a must) are very appealing and the total wattage is about the highest I have seen for the price. I have two questions. Is the HT-Z520 worth the money and will it perform? Can I build a system piece by piece, spend less money for more, and come out with a better sounding system? Any information will be greatly appreciated.
You have $500 for both a receiver and speakers? In that case, an HTIB, such as the one you are referring to, is your best bet.
CJ
I'm not sure buying separates will allow for spending less money for more, but it will allow you to spend $500 now for say a receiver and two bookshelf speakers. Then over time add a sub, rear speakers, and finally surrounds. If you want everything now or don't plan on ever spending more than the $500 then I'd recommend the HTIB as well. There are both the HTIB forums and the Speakers section of the audio area that you should read. Doing a search you should be able to find others with similar budgets and what they went with.
A few things to keep in mind, $500 for both a receiver and speakers would be considered a tight budget to many on the forums. System total watts has nothing to do with the actual sound quality and more to do with marketing so I wouldn't use it as a metric for comparing systems. Read up on the difference between peak watts and RMS power and if you have somewhere such as a Best Buy to listen to the speakers your best bet is to simply go to a store and listen to the choices in your price range. Buy whatever sounds the best to you.
1 - 6 of 6 Posts
