I have a pair of boxes I made when I was actively doing competition car audio a few years back. I just moved into a new place and set up my HT room, I am not satisfied with the output I am getting from my current sub which is a Klipsch RSW-12d. I want to take the two boxes I have and modify them to work nicely in the HT. They are currently tunned at 37hz if I remember right and their dimensions are:
width - 19.75"
Height - 24.5"
length - 27"
cutout diameter 14"
port
width - 7 7/8
length (left to right) 6 3/8
Depth - 16
The front of the box where the sub cutout is has a 1.5" front wall. all made from 3/4 MDF. Some internal bracing but not enough currently, might use treaded rod to brace the box so I do not lose internal space.
I do not have an amp or drivers currently so I need advice on what to buy. I considered using an ep2500 for the subs but I have no idea what sort of active crossover I would need. I obviously need a 15" driver.
My current equipment is an Onkyo sr805 receiver, all Klipsch reference speakers RF82 up front, RF 52 in the rear and an older model KLF-C7 center.
The room is about 13x18 when the blackout curtain is closed and if that is not closed the room is open to the rest of the basement.
I want a loud but deep sound from the subs, should be able to feel them strongly during good actions. The room is mostly all concrete and I still need to try to treat the walls somehow.
Here are some pictures so please give any advice that might help me. Thanks
back of the room curtains partially open to rest of room. They close all the way though and black everything out.
width - 19.75"
Height - 24.5"
length - 27"
cutout diameter 14"
port
width - 7 7/8
Depth - 16
