First time poster so hopefully give all info needed to get a decent response.
On the search for my first Plasma purchase and believe I've narrowed it down to these 2 models:
- Pioneer PDP-4271HD
- Panasonic TH-42PX75U
Would like to get pros and cons of each for my situation. Some info...
- Sit approx. 10' away (believe the 42" should be OK for this distance)
- in a room with lots of light and big windows...so certain times of the day the sun glare can be an issue.
- basically using it for watching TV, sports and movies only (no gaming or computers)
From the info I've gathered so far is that both are nice units, but Pioneer will have a bit more realistic picture (more 3D looking) for my uses as it has pixels "in the front" rather than pixels set back further in the Panasonic. Also, with my sometimes glare issues, the Pioneer has an anti glare screen which the Panasonic does not.
The Pioneer is also $400 more so not sure if it's worth the difference.
Not sure if either of these units have a swivel type stand possibility as that would be really nice in my space to easily turn it when needed with the sun glare, if in kitchen cooking, etc.
What do all of you experts have for me? Thoughts, tips, suggestions, other models to look into better than these two, etc....my ears are wide open as I'm a newbie to this world! Thanks in advance.
**Edit to add that the max. I'm willing to spend is $2,000 (obviously the cheaper the better, but would rather spend a little more for reliabilty, picture quality, etc.)
