Help me decide! Tensioned/non-tensioned Dalite??
826 Views 8 Replies 5 Participants Last post by  jonnyb
Just moved to a new house. My old house had a smaller theater room with a dedicated wall, so I rolled on some ScreenGoo with great success. I had an NEC LT240 DLP projector at the time.
My new house has a much larger room that I'd like to use even when I'm not controlling the lighting 100%. So, I located my 42" plasma on the front wall, and was thinking of a screen that would come down in front of the plasma.
I'd like to go electric and have pre-wired for it already, but the more I read the more I don't want to have to deal with curl and wrinkle issues, so am leaning towards a tensioned screen from Dalite.
But, I have no experienced with any of these so wanted to get some opinions - I want to do it right, but the cost of an electric tensioned is quite high for my budget .
If it matters, I'm planning on an Infocus 7205 on a 116" wide 16:9 screen. The room is approximatedly 22' x 24' or so.
Any recommendations??
Status
Not open for further replies.
1 - 9 of 9 Posts
I can only comment on my screen size, 80x45 (92" Diagonal). I have a Da-Lite Model B Deluxe with tensioning arm. The material I picked is Video Spectra which has 1.5 gain (compared to High Power's 2.8). I had read about Video Spectra notorious waves forming over time. But I still chose it because of the moderately high gain, the viewing cone (35-degrees) and finally because of the included tensioning arm.
So far, I am happy to report the screen is flatter than when it first arrived (3 days ago). By this I mean, when I first put it up I noticed a stretching effect whereby the top and bottom were perfectly flat. But on the sides I noticed it was a little loose and not as flat. After 3 days of having it permanently down, I can now say the screen is perfectly flat on all 4 sides.
I can't comment on the Video Spectra's performance yet, until I receive my hs51 back from Sony service center. But so far, I am very pleased with the shape the screen is in. Perfectly flat.
Model B Deluxe Video Spectra 1.5 80"x45": MSRP $177
Pretty cheap, I think, for something that looks like a Da-Lite Perm Wall screen MSRP $500.
See less See more
The Da-Lite with the tensioning arm only applies vertical tension. I owned one of these screens for about a year. While I couldn't complain about the price or the screen material, I noticed a wrinkling of the edges starting at about 3 months. This produced waves. After further research, I realized that both vertical and horizontal tension are needed. Although it is costly, I went with the Stewart Tab-Tensioned motorized screen. This provides both vertical and horizontal tension and there has not been a hint of a wrinkle or wave in nearly 2 years.
Please indicate the Da-Lite screen material used, size and also how frequently you pulled down the screen. Thank you.
Matte White, 90" diagonal, pulled down once daily.
Thanks for the replies guys. Is the Da-Lite with tensioning arm the same as a tensioned screen?
No it is not. I think your best option would be to go with an electric tab-tensioned screen. Tab-tensioned screens will not get wrinkles or waves AFAIK. I would either contact AVS or Da-Lite by phone and tell them your requirements and see what they recommend.
Agreed. They are not the same creature. If I recall correctly tab-tensioning is available only in motorized screens. I would recommend contacting Jason at AVS. Tell him that I sent you :)
I had posted this in some other threads as well, but a nice compromise between high priced tab tension and typical non-tensioned is Vutec's VuFlex Pro material. It is a thick screen material (non-tensioned) that is resistant to wrinkles. I ordered the Lectric 1 RF model with the VuFlex Pro material through AV Science. I have been very happy with the screen so far. The price should sit somewhere in between regular electric non-tensioned and electric tab tensioned. The other nice feature is the the RF transmitter is built in already and you don't need to pay extra for a remote kit.
1 - 9 of 9 Posts
Status
