I have a th42pz77u that i got last year for $20 and it had 7 blinks so I disconnected a bad FET on SC board did update and been fine ever since.
2 months ago I got another th42pz77u for $20 had 10 blinks so I bypassed a blown fuse and boom it works.I decided to keep it as a spare since it had no stand.
yesterday got another $20 10 blinks th42pz77u fixed same as second one.
I only want to keep one of the spares here's the info on each
1,
pros
+3,000 hours
+seems to run cooler
+brighter whites
+no dead pixels
cons
-frame beatup from laying flat in my work car
-when I first turned it on there was a half screen vertical 1 inch bar that went away after I removed cover pushed connectors and it never came back
-lighter blacks
2,
pros
+very clean taken care of
+better blacks
+no issues
cons
-13,000 hours
-seems dimmer than other one bumped contrast 3 notches gets close but whites look slightly duller.
-2.5 dead pixels (one flickers)
which one is a keeper? plasma is dead so in a few years they'll be dead or dying....
I would keep neither and take them to either the junk yard or the local Goodwill. You can still buy a brand new plasma today, for a bargain if you look around. Even the lower end LG's will be much better than those two you have.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
AVS Forum
