Hello all,
I have a Sony STR-DN840 connected to a Samsung F8000 (60") and love the combination but I do have a nagging problem. Right now, I have the HD set top box connected to the SAT/CATV input with the output running to HDMI 3 (ARC) on the TV. When I'm watching cable TV, the audio plays through my floor speakers as expected and I can control the volume with the Samsung remote. If I select Smart Hub with the remote then select the Netflix app or try stream from a website using the TV browser, I get no audio unless I turn off the Sony. At that point I can restart the apps and play audio over the TV speakers.
I've seen a couple other posts in the Samsung F8000 thread from other folks that seem to be describing the same problem but not definitive resolution. I've also seen posts from folks that say Netflix works fine for them. So, if someone would please give me some ideas on what I might be doing wrong or what I might check in my setup to get this problem resolved I'd really appreciate it.
Once I get this fixed, I can try to figure out the whole Air Play thing...good times.
Mike
Hello all,
Mike
