These speakers were stolen and my insurance company will cover cost of similar speakers made today.
The specs are as follows for the main speakers, and the center speaker is an identical speaker minus the sub-woofer. I found the specs from two sources and listed the details below.
If current speakers are all going to have much better specs, I'd like to know what the highest end speakers that have a similar setup with the built-in subwoofer.
Since these speakers were around 5k retail combined in 1995, I'm looking at something around 10k-20k in todays dollars as a potential maximum price. Is there is anything in that price range that I can justify as being somewhat comparable to the Infinitys?
Thanks very much for any advice or recommendations. I spent a lot of time researching all my components back in the day but have no idea where to start in looking for current comparable replacements.
SPECS:
Four-way dynamic loudspeaker with integral woofer amplifier.
Driver complement: 12" woofer, four 5.25" lower-midrange units,
two 4" upper-midrange drivers,
1" soft-dome tweeter.
Crossover frequencies: 110Hz, 350Hz, and 3kHz.
Frequency response: 25Hz–20kHz ($*–6dB at 25Hz); 35Hz–20kHz ±2dB.
Sensitivity: 96dB/2.83V/1m (anechoic).
Nominal impedance: 6 ohms.
Amplifier requirements: 10–150W.
Dimensions: 7.5" W by 19.5" D by 54.75" H. Weight: 78 lbs each.
SPECS (from another source)
Type: 4 way, 8 driver loudspeaker system
Frequency Response: 25Hz to 25kHz
Recommended Amplifier: 10 to 150W
Crossover Frequency: 110, 350, 3000Hz
Impedance: 6Ω
Sensitivity: 96dB
Bass: 1 x 300mm
Midbass: 4 x 125mm
Midrange: 2 x 100mm
Tweeter: 1 x 25mm soft dome
Dimensions: 194 x 1390 x 500mm
Weight: 69kg
SPECS:
Impedance: 6Ω
Sensitivity: 96dB
Bass: 1 x 300mm
Midbass: 4 x 125mm
Midrange: 2 x 100mm
Weight: 69kg
