I have recently moved to the house i am in. its about 20 years old. the room where my HT is in seems to have 3 circuits. all the receptacles are wired to separate the top and bottom plug in. i have lamps plugged in to the upper pole which are controlled by a single switch. the lower pole is unswitched and it where i have the ht plugged in. nothing else on this except a small wireless network extender. in the room there are also 4 120 volt overhead recessed lights on a 3way switch. Initially the lights were on a dimmer and there was terrible hum through my Denon AVR-3300. I changed it out for a fixed 3way switch and the hum seemed to go away. The other components in the system that are draw power are: 1) Samsung DLP TV, Pioneer DVD, Panasonic VCR, SA 3250 box, Samsung STR-165, a 7777 Channel Master TV amp, and a Def Tech Supercube 1. I have noticed recently that my reciever will reset or get confused and act like it lost the audio signal. It shows the channel levels on the display and then goes back to ProLogic or whatever. I initially thought this was due to OTA sound signal dropout and blew it off. Last night I was watching the ALCS game on my SA 3250 which feeds digital audio through a coax cable. It did the same thing as the OTA box and caused the Denon to act like the power had been cycled on and off and then I lost all digital feeds and any analog feeds had the hum back. I powered everything off for about 3 minutes and it all came back to life. It happened again tonight during CSI on the OTA feed but it didn't cause the hum problem (the OTA feed goes through a toslink cable).
My question: this seems to me to be coming from the power supply to the room. is this from a voltage spike? i have it all hooked up to a surge protector but its the usual sams club $30 variety. i have read a few of the threads about the monster conditioners with interest. if they live up to the hype, will they solve the problem. if so, which product is best for me? if this isn't my problem, any ideas?
thanks for any replies.
