1 - 4 of 4 Posts
hello to all,
I am french and excuse me for my low level of English.
I would like to connect 3 Western Digital my passport in case Western Digital HD TV.
I bought a hub usb 2.0 7 port powered Belkin brand but I can see only two out of three HDD.
Someone can help me solve my problem if a solution exists.
Thank you
If I remember correctly Western Digital officially ditched USB Hub support in the newer official firmwares!
Follow the link which hitechluddite posted to find out how to get USB hub support back!
You can either use an older firmware that still supported hubs, or use a custom as mentioned, or experiment with different hubs, as apparently some of them still work. More info on which ones is buried around here somewehre, or at the other link provided
1 - 4 of 4 Posts
