Hello. I have a hefty investment in this unit and am trying to resurrect the Monster MCC AVL300-S remote and Omnilink RF to IR bridge with my recently updated AV components. I've done the internet-based setup for my components but have not been able to get anything out of the Omnilink IR blaster. When I changed the configuration for my components to be controlled directly from the AVL300 remote (via infrared), everything works fine. But I think I've not paired properly with the Omnilink. An internet search took me to a post that said that if you mess up the pairing the first time, or press the "connect" button on the Omnilink, you're screwed.
In the Monster Central online configuration interview, I checked the control via Omnilink box and specified ports and chose IR Blaster-- didn't work-- and then redid the setup choosing "All" and it still doesn't work.
I've read about two other users that had this problem. They found a solution (from Monster Central tech support) to get the Omnilink paired, but they didn't post their solution. I haven't been able to get thru to Monster support. Anybody? Thanks.
